ВАЗ 2103 1979 года выпуска.
Как и обещал в своей теме, выкладываю фотки машины.
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:13:17Image taken on:Вс май 18, 2014 14:13:17Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:13:28Image taken on:Вс май 18, 2014 14:13:28Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:13:39Image taken on:Вс май 18, 2014 14:13:39Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:13:53Image taken on:Вс май 18, 2014 14:13:53Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:14:02Image taken on:Вс май 18, 2014 14:14:02Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:14:20Image taken on:Вс май 18, 2014 14:14:20Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:14:29Image taken on:Вс май 18, 2014 14:14:29Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:14:41Image taken on:Вс май 18, 2014 14:14:41Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:15:00Image taken on:Вс май 18, 2014 14:15:00Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:15:13Image taken on:Вс май 18, 2014 14:15:13Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:15:21Image taken on:Вс май 18, 2014 14:15:21Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:15:34Image taken on:Вс май 18, 2014 14:15:34Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:15:47Image taken on:Вс май 18, 2014 14:15:47Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
EXIF-Data show/hideOriginal image recording time:2014:05:18 18:16:09Image taken on:Вс май 18, 2014 14:16:09Camera-manufacturer:SAMSUNGCamera-model:GT-S5830
Re: ВАЗ 2103 1979 года выпуска.
Ну да, я в соей теме писал про нее.Haris22 писал(а):Ну и рычаг КПП
Ниче так, немного усталая, хрома маловато.
На ходу?
Заменили термос только, а то старый был без поторохов и датчик ветродуя новый.
Пороги переварены на ней, двигатель дурной, там под головкой стоит прокладка чугунная или стальная 8мм, колено соответственно другое. Подробностей не знаю т.к. покупали давно ее уже с таким двиглом.
- VLAD
Что-то почти все релюхи на левом брызговике, а на правом только дырки от саморезов остались
А так очень бодрый автомобиль, головная оптика получше чем у меня
- VladiZlav
только на морде решетки не хватат, а так даже арки хром и дверные в хромеHaris22 писал(а):хрома маловато.
На этом аппарате я лет 10 назад ездил. Потом стоял в гараже, а этой весной я его вытащил на свет божий.
Щас батя на ней гоняет, если можно так сказать.
Может кто в теме, как эти блоки форсируют? Там под головкой прокладка стальная в сантиметр толщиной.
Блок что потом, гильзуют? Там поршня на 80 вроде и ход коленвала увеличен по сравнению со стоковым блоком.
зы. блок 21011(если память не подводит)
- Dogfighter
- Мега-Гуру Классики
- Модель авто: Калина 1118
Не понял по мотору. 21011 это же низкий блок. Если коленвал высокий ставят, то короткие шатуны впендюривают, объём повышается. Зачем тогда прокладка,не понял.
- fragment
- Почетный нивавод :)
- Модель авто: Lexus RX330
В 21011 блоке 79ые поршня стоят. Выкинь прокладку да зажигу отрегулируй и норм будет. А так облицовку бы родную и повторители и вообще красотра была бы.
Там на 80 или 82 блок точен, колено другое, ход больше, вот прокладка и стоит. На выходных ближе сфоткаю.fragment писал(а):В 21011 блоке 79ые поршня стоят. Выкинь прокладку да зажигу отрегулируй и норм будет. А так облицовку бы родную и повторители и вообще красота была бы.
- Dogfighter
Во-во, я о том же. Иначе зачем ход колена увеличивали.fragment писал(а):Тогда шатуны укороченые бы или поршня со смещенным пальцем.
В общем не понятно что с двиглом делали, но рвёт он отменно.
После запорожца когда сел
- marapulec
- Модель авто: ВАЗ 2105 1.2л
При установке коленвала с ходом 80 мм в блок ваз 21011 поршень выходит из блока на 7 мм,а кольца остаются в блоке.Этой проставкой компенсируют эту высоту.LЁLIK писал(а): там под головкой стоит прокладка чугунная или стальная 8мм
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 101 гость
